Oracle User Scott not accessing
Asked By 140 points N/A Posted on -
I am using Oracle to learn SQL. Just introductory. I downloaded the Oracle setup file from Oracle's homepage named – "oracleXE 10g". The software installed successfully, but I don't seem to find the user Scott, which was used in the class lecture. I missed the lecture so could not figure out if there was anything said which was not covered in the papers. I asked a partner who said it was a default user. Then why can't I access it? Do I need a configuration or something to be set up at the beginning? Or am I using the wrong version? The instructor said in the paper that it was 10g, are there any variance within 10g?
Best Answer by technical007
Answered By 0 points N/A #91839
Scott user is not in the default user list bundled in Oracle XE. You have to create it manually or by running a script. Go here to download the script.
First of all, create a user named, Scott and password, Tiger or as you wish. Log into it and the run the script on your SQL command line.
Answered By 140 points N/A #91842
Thanks for the answer. The link seems broken. Would you please post the link again?
Answered By 140 points N/A #91845
Thanks. I have created a user named Scott but it doesn't let me log in.
Answered By 0 points N/A #91846
That is because you have to grant some permission to it. Here is a script that does everything, you shall find it in the 3rd post :
http://www.dbasupport.com/forums/showthread.php?34990.html
  • Copy Script , save it in a text file, with extension " .sql ".   When done, open up the SQL command prompt.
  • connect  sys as sysdba   and give password
If you already have a user named Scott, you may want to drop it first. Issue :
  • drop user scott cascade
  • Now enter the character  '@' the command prompt and drag and drop the scriptfile.sql you just created.
  • Press enter.
It will take a while till your user is up and ready.
Answered By 140 points N/A #91847
Thanks, technical007 and softwaresynthesis, both of you. I got my problem solved!
