Ordinal Not Found error on PostgreSql
Asked By 1300 points N/A Posted on -
Hello guys,
 I am using Ruby under Windows XP 32bit
DB: postgreSQL 8.4, when trying a to get connected I get this message somewhat like this
ruby.exe – Ordinal Not Found
The ordinal 284 could not be located in the dynamic link library SSLEAY32.dll
My idea, but somewhat a sort of a guess is that it seems to be some conflict between the ssleay32 shipped with postgres and the ruby. I understand that I could have gem postgres-pr, but it would be preferable for me to use the ruby-postgres than any other, for I already use this on all my set-ups.
Could somebody share some ideas on this, who are also experiencing the same problem as me, on how you did it?
Answered By 0 points N/A #122866
Do you remember if you've made any changes in your ruby? if you did, it is advised that you restore rubybin to what it was before.
The reason for this is that some of the dll's you may have changed, created multiple copies from cygwin, Google, SVN, Ruby, Postgres, VMware, etc. because some of the dll's are outdated and new dll's are adde to PostgreSQL.
Anyways, you can try these steps.
Copy the files here C:Program FilesPostgreSQL8.4bin
Rename these two dll's libeay32.dll and ssleay32.dll, found in {RUBY_PATH}/bin directory
Then copy those renamed dll files to {POSTGRES_PATH}/bin directory
And paste it under {RUBY_PATH}/bin. rename those 2 files in C:rubybin, before you post it for back-up in case you might Need them for other reasons. 🙂 after doing that, set your database.yml like this.
Development:
Adapter: postgresql
Database: DATABASENAME
Username: YOURUSERNAME
Password: YOURPASSWORD
Host: localhost
Encoding: UTF8
Run rake db:create and rake db:migrate. you should get a go after this.
Chronicling My Ruby on Rails Journey and click here
