Organisational units in active directory context
what limits the Organisational unit (OU) in active directory from fully limiting the access permissions and privileges to users within the same organisational grouping whereas  the main purpose of active directory is to restrict access privilledges from a central administrative location?
Answered By 0 points N/A #85326
I think you may using corrupted active directory. If you can not install it then follow this.
Install active directory:
To solve this problem install active directory properly. Give a perfect domain name for active directory. Use @, .com etc for creating a domain name. Then create a user under this domain. Give IP address for every user. Then finish user creating process.
Here is a way to configure users in active directory:
To do this just go to my computer > properties > Computer name. In this tab there is an option named to rename this computer or join a domain click change. Click on this button.
Then in member of option click domain radio button then give a domain name perfectly. After that search for a new domain. If available then restart computer and log in with a new domain.
