I have dozens of desktop icons that needed to organize. Those icons are the result of setting up a few e-mail accounts using BIS. Those icons are so many that it occupies too much space on my desktop. I want this mess to be organized by creating a folder where I can transfer all the icons. Is this possible? There are instructions for doing it but since I’m using an old hardware, these instructions won’t work.Â
Organize Desktop Icons in Blackberry
Hello there! It is easy to move the desktop icon inside a folder on a Black Berry phone. First, highlight the icon that you want to place inside the folder. Then open the menu. Select the Move to Folder and a list of folders will appear. Select the desired folder where you want the icons to be located. And that's it. Whenever you need to access the icon, just open up the folder where you placed it and it will be there. If you want a video tutorial about this, check out this link:
Hope this helps! Good Luck to you!
