OS errors in a server
Well most OS had an errors. There was no free error in every OS. You just need to maintain your PC from bad sector, virus and anything that is threat to your computers. The best way to check errors is chkdsk. It enables you to determine and verify files, data, security description and most importantly to attempt recovery of bad sectors that would make your hard disk life span long.
This will ensure you a good protection, stable performance and the stability of your hardware/software from time to time.
Hope does it work to you because the life span of your application and OS errors depend on how you maintain your computer against from unexpected situation like having improper shutdown may result also this damaging your some of applications.
All OS have errors, they are not error free especially when introduced to a software. It is very important to verify the identity of your OS file system. And the very important reminder is for you to always check your data, file, journals and the like and do some verifications. Proper maintenance and protection are also some of the best way to protect your computers.
You may also visit this site for a complete list of Web Accessibility Evaluation Tools
Millet
