Mary West
30 points
Posted on - 05/29/2012
I am trying to install AutoCAD Architecture 64 bit, but, it does not install because it is saying that there is an issue with the OS compatibility. I am not sure of what is going on, but, I need this to be installed right away.
I have a very important deadline to meet. I would also like to ask if I can convert AutoCAD 2010 to AutoCAD Architecture? I would really appreciate your immediate response on the matters at hand.
I may not be able to pass my subject if I cannot fix this issue in one hour. I desperately need your help with this problem.
Autodesk Inventor
Professional 2012 (English) 64
Bit
Open File "1fe9e1772cb8b7e4b56388a7ff44ec45ff8cba35'
? "1fe9e1772cb8b7e4b56388a7ff44ec45ff8cba35" is a file which was
downloaded from the internet. Are you sure you want to open it?
OS incompatible with Autocad Architecture installation
Since you are planning to install AutoCAD Architecture 2012 64-bit, this version also requires a 64-bit operating system. Maybe you did not check first the system specifications of the program that you’ll be using and installing.
This information should be checked first before installing an application. And here, since you’re the one who’s saying that you have a system incompatibility issue when you tried installing it this only means that the operating system that is running on your machine is the 32-bit one.
This problem with your AutoCAD Architecture 2012 64-bit can still be fixed by installing the 64-bit version of your operating system. For example, if you are using Windows Vista 32-bit any Service Packs, you just need to replace it with Windows Vista 64-bit or any Windows versions that is 64-bit.
AutoCAD Architecture 2012 64-bit works on Windows XP 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit. So, to fix your problem with AutoCAD Architecture 2012 64-bit you just need to install any of the 64-bit versions of the operating systems above.
You should format your hard drive and then install Windows XP 64-bit, Windows Vista 64-bit, or Windows 7 64-bit. And just install AutoCAD Architecture 2012 64-bit after installing Windows.
