Hello
I got an error message while downloading Operating System X Mountain lion in the App Store.
The error message is "An error has occurred"as well as never desires to launch downloading once more.
I need a solution.
Thanks a lot.
OS X Mountain Lion App
Hello
It seems that you have an unstable internet connection. While you are downloading the OS your internet connection is losing the connection which is what is causing the error.
A download manager is what you need. FOIX can be found. When your internet connection loses connection the program will allow you to resume from where you left off. No need to start the download from the beginning again. There is a free and paid version. The paid option allows multiple threads which means your download speed will increase.
If you are still not able to download the OS, you can buy the DVD
