OSI Reference Model and TCP/IP Model are same
List two ways in which the OSI Reference Model and TCP/IP Model are the same. Now, list two ways in which they differ.
Solution:
Both models are based on layered protocols.
Both have a network, transport, and application layer. In both models, the transport service can provide a reliable end-to-end byte stream.
On the other hand, they differ in several ways.
The number of layers is different, the TCP/IP does not have session or presentation layers, OSI do not support internetworking, and OSI has both connection-oriented and non-connection service in the network layer.
Resolution:
Each of those styles depends on split methods. Both
equally contain a networking, transfer, and also program level. Within each version,
this transfer services provides a
trusted end-to-end byte mode.
However, that they are different in a number of methods.
The amount of levels differs from the others, the
actual TCP/IP doesn't have period or even demonstration levels, OSI don't service
internetworking, and also OSI has got each connection-oriented as well as non-connection
services within the networking level.
