Other alternative for iTunes as cd ripper for Mac?
Hi guys, I am using itunes to rip my music from original cds. Can you suggest to me other possible cd rippers for mac besides itunes? Thanks.
Max is a good alternative application for creating high-quality audio files in various formats, from compact discs or files. Else, try NMP3 Ripper. But itunes is mush better & if you want a higher quality encoder you can always install the Lame Encoder for iTunes.
Hello Eckel Andrea,
I would suggest X Lossless Decoder. It can rip CDs and turn them into lossless audio. This is for Mac Operating Systems and its free. It requires an Intel/PPC and a Mac OS X 10.4 or higher. The latest version is 20121222 and can be found here.
https://www.macupdate.com/app/mac/23430/x-lossless-decoder
Before you rip those CDs, you can use MusicBrainz to tag information to your music. You can download it here:
Hope this helps.
Notifications
