Other PC with no installation disc
I have a Netgear WGR614 and I need to install it to other computer but I don't have any installation disk with me. How can I install it without needing any disk?
Normally these routers or modems come predefined by the system and you don't need to install or use any kind of drivers or software’s to use them. But still if you are getting some issues, do the following.
If you have a network card but doesn’t have its driver, there’s no way you can install and use it. Microsoft doesn’t have a generic driver for this device and can only detect it but not install it. For your NETGEAR WGR614v9 router, the following firmware updates are available from the NEATGEAR Support page:
For other NETGEAR Wi-Fi router model, go to NETGEAR Support and search for your product. You will need your router model number here.
