Our McAfee 8.7.1 updates manually but does not update on its schedule.
Our McAfee 8.7.1 updates manually but does not update on its schedule. Can anyone help? Most web traffic is allowed on our proxy server.
For the McAfee to be able to carry out the automatic updates, you will need to make sure that you have set it to updates itself at a certain time in its settings. And even after you have set that, you will need to make sure that you computer is connected to the internet at the time which you set it to carry out the automatic update process, for the process will not be successful otherwise.
You can also set the antivirus to carry out the automatic updates as part of the windows updates, and that means that you will need to set it to update itself automatically when the windows updates are being downloaded and installed on your computer.
Mathew Stone
I also had that same kind of problem with my old McAfee antivirus. Mine was ok since it has 3 years subscription but similar to you, it doesn’t update automatically. It needs to be updated manually and we all know that antivirus programs need to be updated on a regular basis so it’ll become effective in detecting and removing threats.
My solution to that is to use a different antivirus for my computer since most antivirus programs nowadays are already self-updating. Here are several of the ones you can use:
