Out of the office in Outlook 2010 does not work properly anymore.
After upgrading to Office 2010 from Office 2003, our out of office in Outlook 2010 does not work properly anymore.
Our email server is still on Exchange 2003. Could this be the reason for our problem?
Please let me know if you have encountered the same problem and how it was solved.
Thanks!
Answered By 590495 points N/A #99173
Scan the hard drive for errors. It is possible that an error in the file structures of the hard drive occurred after upgrading from Microsoft Office 2003 to Microsoft Office 2010.
If you have a disk utility application installed on the computer, use it to check the hard drive.
Or just use Windows built-in disk tool.
  1. Right click on drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now.
  4. Check Automatically fix file system errors and then click Start.
If doing a disk check on the hard drive did not fix the problem, uninstall Microsoft Office 2010 and then install it back afterwards. If the problem is still not fixed, try uninstalling Microsoft Office 2010 and install the originally installed Microsoft Office 2003. Check if Microsoft Outlook 2010 is already working now.
