Outlook 2003 and Exchange 2007 based Calendar Issue
I have a user that has to share her Outlook 2003 and Exchange 2007 based Calendar and the problems that 3 tabs are missing including the permission tab. I tried solving and figured out that it is a faulty profile, because if I rename her origin and log her on to the computer and create a new profile, the tabs are all there. Do you think I should stick to this solution or is there another way I can fix this problem?
