Outlook 2003 Not Supported Calendar Message
I'm using a web application that I have integrated with Outlook 2003.
The web application works with “ical4j” in order to establish invitation for meetings.
It works quite smoothly with Outlook 2003 though it has some issues with Outlook 2007 and Outlook 2010 users.
I need your suggestions on how to make the “ical4j” compatible with Outlook 2007 and 2010.
Thank you.
Answered By 5 points N/A #136552
The first thing that I would suggest is enabling the Outlook Compatibility. Try this link for some idea:
In modifying the compatibility the link below will show you how to do it manually and one by one .
There are also different aspects that we need to look through regarding your question. I need to know if the ical4j is fully not working or if there are just some parts that were not functioning. It would be very helpful if you can identify the conflict one by one so that we can apply the proper solution.
Or if which function of the ical4j is not working properly.
