kate harry
10 points
Posted on - 01/18/2012
I am unable to open certain attachments in my Outlook 2007 because of the error message “Outlook blocked access to the following potentially unsafe attachments”. What setting changes should I make to resolve the issue?
Outlook 2007 block access to unsafe attachments
Hi Kate,
Emails with this type of errors means that Outlook tried to remove it thinking file may be a virus. To go around the error you may try a few things.
· You can try to ask the sender to upload a file on a FTP site then provide you with the link. This usually should be the case if the file being sent is an .exe file.
· You can try to change the file name of the attached file with the use of a utility compression.
· You can rename the file extension by adding a character or two. Just inform the person what file type it really should be.
Aristono
