Outlook 2007 – Sent Folder
When I look in my sent folder I see my mail in three columns: Sent to, date, and size. How do I include a column showing the subject(reference) for each email?
Thank you
Thank you
Hi Glenann,
Following these steps:
View > Arrange by > Custom… > click on Fields button
In “Select available fields from” combo box, choose group in which your field(s) want to add belong to
In “Available fields” column, choose the field you want to add. If you want to choose more than one field, hold Ctrl key and select them
Click on button Add ->
Your new column will be shown in “Show these fields in this order” column. Use Move Up or Move Down button to re-order your columns
Click OK button (twice)
Hope this helps
Hi Glennan,
If you are still in search of a simple way to achieve what you want then I have one for you. Check steps below.
1. Open any Mail Folders.
2. You will find the labels of the columns up top.
3. Right Click any of these columns.
4. Look for “Subject” then click.
Hope this helps. Keep us posted.
