I am facing an issue linking to” Exchange Server” through outlook. I am receiving the below error however at what time I attempt to associate the fresh Outlook email account in Outlook 2007 or Outlook 2010?
The connection to the Microsoft Exchange Server is unavailable. The outlook must be online or connected to complete this action.
OK
I need someone assistance please
Outlook 2007/2010 Not Able to Connect to Exchange Server has occurred
Hi there Calvin S Cole
If the default gateway is not configured in outlook client computer this problem will occur. So to solve this problem there are two ways.
1st – Manual way
2nd – Automatic way
1st Method (manual) for outlook 2007
Step 1 – Click Start > Run > type regedit and hit enter and open regedit editor
Step 2 – Locate the following path
HKEY_CURRENT_USERSoftwareMicrosoftOffice12.0OutlookRPC
Step 3 – On the right hand side click right mouse button > New > DWORD Value
Step 4 – Give the name as “DefConnectOpts” and hit enter
Step 5 – Set the value to “0” in value data box the click modify
Step 6 – Exit the regedit editor
Note – If it is for outlook 2010 you need to use this path
HKEY_CURRENT_USERSoftwareMicrosoftOffice14.0OutlookRPC
2nd method
Download this software which provided from Microsoft for overcome this issue
How to use? Download it > install > run the program > done
Hope these answers helps you
Taylor B Campos
Thank You..!!
