Outlook 2010 save a HTML file
I was facing a problem where I was exploring Outlook 2010 and message stay indicating me to save a HTML file.
X2007srv.labs.local
Information you exchange with this site cannot be viewed or changed by other. However, there is a problem with the site's security certificate.
The security certificate is from a trusted certifying authority.
The security certificate date is valid.
The name on the security certificate is invalid or does not match the name of the site.
Do you want to proceed?
Yes No View Certificate
This message comes every time from the time you explore Outlook and it will carry on till you end Outlook.
What is this problem?
