Outlook 2010 shows Offline and never turns Online
Everything was working fine till today and now i can see its always offline and when i manually click the online also it stays offline
Any ideas on how to fix this offline issue on my Outlook?
Answered By points N/A #170291
To repair the Microsoft Outlook Work Offline error follow the below steps.
1. First of all restart your Outlook client.
2. Then click on the "Send/Receive" tab.
3. And finally click on the “Work Offline”.
But Microsoft solution is creating a new Outlook Profile is the best way to solve this problem. To create a new Outlook profile follow these steps:
1. Click on the Show Profile button.
2. Select add button.
3. Then follow the instructions & Outlook will connect to the Exchange server which will help automatically to create a new profile.
4. With a new profile you will able to have Outlook prompt you regarding which profile you wish to utilize while Outlook starts.
5. If you specify a profile make sure you specify the new one you just made. This will confirm Outlook will start up and search for a connection to the Exchange server rather than disregard the Exchange server and Work Offline.
Hope after that you will not face any problem.
