adabark
Posted on - 10/28/2013
Outlook 2013 how can i configure Exchange mails. I have this freshly installed on my Windows 7 system but now have no clue how to configure it. Can i have the step by step on how to configure.
I should have upgraded the office on my existing version but ended up formatting my system which has led me to this point
Regards
You can configure exchange mails on Outlook 2013 by following steps:
Step1: Launch Outlook 2013. As you run Outlook 2013, a setup wizard will run. Click Next
Follow as shown in the figure
Step 2:
Step 3:
Step 4: Server: text in your Microsoft Exchange Server, it depends on your email server provider.
User Name: Login Id
Step 5: Follow if configuring Outlook 2013 64 bit, else skip
Step 6:
Step 7:
Step 8: write the address for your email server
Step 9:
Step 10: Click OK on the alert window pop up
Step 11:
Step 12:
Step 13: Click on Finish. Restart your Outlook and your Exchange mails are configured.
