I would like to configure OUTLOOK ANYWHERE IN EXCHANGE 2003.Â
We have Exchange 2003 in windows Cluster mode. Can you suggest me how to configure outlook anywhere in Exchange 2003 cluster mode?
Also, Is SSL certificate is mandatory to get it installed? Is any temporary SSL certificate can be generated to furnish the installation testing for the time being?
Thanks & Best regards, Bipin
Equans
Outlook Anywhere Configuration in Exchange
Start Windows Small Business Server 2003 and run an email configuration and the Internet Connection Wizard. Then, follow these steps:
a)Â Click start -> Server Manager.
b)Â Click To Do List -> Click Connect to the internet.
c)Â Specify your connection type, DNS server, and router.
d)Â Go to the web service configuration page.
e)Â Select Outlook via the Internet, and check 'allow access to only the following web site services' from the Internet.
f)Â Click Next.
g)Â Go to the Web Server Certificate page, select your type, and click next.
h)Â You can choose to install a new server.
i)Â Configure your email profile.
j)Â Test RPC for XP client.
I hope this helps.
