Outlook Error Code 0x80040900 Fix
Whenever I try to send an email using outlook, I keep getting an error message with an error code 0x80040900. I am not aware of the problem and do not know how to solve this error. Can someone help me with this?
The error you are facing is pretty common and comes with a relatively easy solution. The error code you mentioned means that there is some problem with the configured server address or the port address configured with outlook. This basically means that outlook is unable to connect to its servers.
What you need to do is check your internet connection. Sometimes, the problem is simply that the internet connection is broken. Once you do this if the problem persists then go to your account settings and correct the port addresses.
