anonymous
7060 points
Posted on - 11/05/2011
I have two domains “DOMA” and “DOMB” trusted Calendars CALB in a “Public Folder” on “DOMB” Reviewer’s permissions of a DOMA calendar and user Started outlook from DOMA. I can open CALB but I can’t view it’s contents. Does any one have any clue as to why?
Outlook Errors Is anyone familiar
First of all I will be interested to know which antivirus you are using because if you may be using the AVG free antivirus, then I will suggest that you go to its control panel and then look for the Email scanner, click on it and then choose configure. You will need to uncheck all the 'certify email' options.
Otherwise I will suggest that you run a detect and repair utility to find any errors that might be causing that problem and fix it.
Or may be you are not going do not have enough permissions for the temporary internet folder, or maybe the folder could be corrupt so you need to flush out and then make sure your user status is high enough on the machine that you are using.
__
Regards
Clair Charles
