Outlook experienced a problem with the Microsoft Outlool Mobile Service
Hello friends,
I am experiencing a terrific problem with Microsoft Office Outlook. I have this error only after adding the mobile service to Outlook. I tried to run the update for it, but no luck still I am getting this same error. I am not sure whether this is not compatible with this software. Please help me to resolve this error. Thanks.
Outlook experienced a serious problem with the ‘microsoft outlook mobile service’ add-in. if you have seen this message multiple times, you should disable this add-in and check to see if an update is available. Do you want to disable this add-in?
