Outlook express gives error(connection failed)
Hi
I am using outlook express.suddenly it gives error :connection to the server has failed socket error 10061 error number 0x800ccc0e.
Thank you
Hi
Thank you
You may check your Microsoft Outlook Express settings making sure that the POP3 and SMTP servers are correct as well as your username and password are not misspelled.
Any typographical errors can cause login problems especially in your server’s name. Be sure that everything is spelled correctly.
If there is no problem in the settings, you may try this one out.
If your attempt fails, try again using POP3.WYITH.NET in step 2.
But if your attempt is a success, then the problem is within the application you are using.
Try reinstalling the application you are using. It is possible that your password got corrupted.
You may also disable your Windows Firewall for the meantime and enable it later when you are finished.
