Hello I installed reQall for version 1.2.0 of outlook and in the middle of the installation I got an error saying
Error:
No supported Outlook is installed (Outlook 2010 (32/64 Bit), 2007,, 2003, 2002 or 2000?
Can anyone help me with this?
Outlook installation Error on Windows with reQall
Can you find the Microsoft Outlook version which is running in your computer.
You can see this by right clicking on the Outlook icon and by clicking on properties.
reQall supports only the versions that are mentioned in the error message given. ((Outlook 2010 (32/64 Bit), 2007,, 2003, 2002 or 2000). I have tried with Outlook 2010 beta version and it does not support.
Hope this helps!
Hello Robert A Raymond,
If you want to use that facility then you have to install those versions which are mentioned in the error message. All you need is to check that which version you are already running on your PC. Because you can only install these versions on your PC as mentioned in the error according to the architecture rules and also some of the software rules.
If you are installing a plug-in or add-on for Microsoft Office Outlook, check and verify that it supports your current version of Microsoft Office Outlook. With that error, it appears that your add-on does not support your current Office Outlook as it cannot find a supported version. Check the supported versions indicated in the error message and verify that you have one of those versions.
“reQall” is from QTech but their website, www.reqall.com, is no longer available. If you are still using this add-on, it is possible that the add-on may have been discontinued. reQall is a nifty to-do list manager that allows you to speak or type reminders on your iPhone which the app then organizes and sends you reminders as well as sync events with Google Calendar, iCal, and Microsoft Office Outlook.
If the application is already installed and gives you errors, try disabling it. Press and hold Ctrl as you double-click the Outlook icon to launch Microsoft Office Outlook in Safe Mode. From there, disable that add-on.
