The Outlook Plugin Tasks Installed Do Not Sync
Hello there! I have recently installed an outlook plugin in my desktop. It seems to be working on the demo but when I try to sync the outlook plugin tasks, it does not work. What will I do?
It looks like you have installed Syncamatic Outlook Plug-in and currently it only supports the blackberry Smartphones and if that is not the case, and you have installed other synchronizing plug in try to turn off the anti-virus software running in your system. In case you are getting "outlook cannot open the task folder.." error, try to add a new task. Sometimes it works.
Regards.
Laz Zebbena
Hi Trevorvalentin,
This is how you remove or disable plugins from your Outlook.
1. Go to Tools.
2. Look for Trust Center then click Add-ins
3. Identify the add-in you want to work with.
4. Look for a “Manage” section then click Go.
5. The next page is pretty much self explanatory.
Keep us posted!
