Outlook problem with script error 2253
I am having problems printing emails from my Outlook. When I try to print, I get the error message “An error has occur in the script on this page”. I get this message in all of my emails that I am trying to print. Any assistance would be great.
An error has occur in the script on this page-error code 2253
Best Answer by Michal
Answered By 0 points N/A #126613
If you want to fix this issue, it can be done very easily. Please follow the following instructions:
Click on START button, Then select RUN. Then just type regsvr32 ole32.dll. Please carefuly note the space after regsvr32. Click OK.
Answered By 590495 points N/A #126614
You may also try uninstalling Microsoft Outlook from your computer and then install it back. This will fix any corrupted files in the installation and will restore its settings back to default. Try it again after reinstalling Microsoft Outlook. You may also try checking your computer for any possible errors.
Use a disk utility application when checking the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton SystemWorks, or Norton Utilities. It is possible that an error in the hard drive corrupted the script in Microsoft Outlook and causes the application to unable to print the messages.
