Outlook protection software to find spam
Some unhealthy emails are received from unknown persons. I want to kick off such mails to spam folder automatically. Which protection software to be used to find spam emails and automatically transfer to spam folder?
Best Answer by Brent kennedy
Answered By 0 points N/A #134962
Unfortunately, there has not been a tool developed yet to automatically send spam emails to the Spam folder but you may want to try using Kaspersky Internet Security 2012 since it has a button "Marked as spam" that allows you to set if the mail is spam or not, then the next time, it will automatically move the email to the Spam folder thus, saving you a lot of time sorting your emails.
Answered By 0 points N/A #134963
Hi Smadisony,
You can also do it manually, go to the email that you want to get rid of, scroll to the bottom part and look for the word "unsubscribe", then click it. I hope these few instructions have helped you.
Thank you,
Adrian Leano
