Hi experts,
When I try to run Outlook Web App., it tells me that it isn’t supported on my system. I heard other people had similar experiences but there is yet a solution. Please help me.
There have been recently quite some buzz about the fact that shifting password during Exchange 2010 OWA is deteriorating with the following error message although the user is not registered with the old version of Outlook Web App.
Need your help to solve this.
Error:
This feature isn't supported if Outlook Web App is set to maximize the blind or low vision experience.
Please help.
Outlook Web App. Not supported anymore?
If your system has any previous version of outlook application, first you have to remove that application completely by using any complete removal software such as (revo uninstaller).
Download a fresh copy of outlook web application (If you have the installation CD that’s fine). Follow the steps:
– Log into you “administrative” account.
– Insert your installation CD into your CD room or if you are installing the application from your download then go to: server/ setup/ I386/ setup.exe.
– Click on custom application and then check “outlook web access”.
– Chose your preferable features from the list and then click “Yes”.
Hopefully the problem will be solved……enjoy!!
