Outlook Web Application 2010 crashes IE9
There is a bug in my Internet Explorer 9. IE9 will be crushed when specific messages got to load in the preview of the Outlook web application 2010 (SP1). I found people talking about this type of problem in the internet. IE9 team has been reported by me, but I found no response from them. So, please help me out to solve this problem.
Thank you.
Answered By 0 points N/A #146780
I faced the same problem a few months ago. I also reported the problem to the IE9 team and did not get any response from them. Then I decided to solve the problem for myself and I tried all the possible solutions. Finally I solved the problem.
I faced the problem because of my antivirus. I use McAfee antivirus and I found out that the problem arises because of McAfee access protection. When I disabled this feature, my problem was solved.
McAfee Access Protection
So, I think you can solve your problem by disabling the feature of your antivirus that is causing the problem. I hear that even Avg anti virus is causing the problem.
Hope this information helps you.
