Shirley
10 points
Posted on - 07/22/2011
Hallo master VB,
I want to ask. Yesterday I created a small program using VB language. After the program finishes, I've running the file exe on a computer that is not installed the VB, but the program would not work and display an error message.
The error message like this.
Runtime Error '429 ': ActiveX Component can not Create Object So just close the program immediately, I've tried to figure out on Google but have not found an answer.
Jayar31
Overcoming Error in VB 6.0
Hi Shirley,
The solution of your problem after you have run the exe files in your computer without a MS Visual Basic application installed is to download the Microsoft Office such as 2000/Windows 2000 Registry Repair Utility. This Office restores your registry settings for several important files to prevent potential issues in your computer.
You must download a components that is compatible in your computer windows that you are using because ACTIVEX control is a kind of registry that helps to run an executable files to load in your computer. Such problem may have a solutions. hope it will help you to solve it.
Enjoy!
JayAr
Shirley
10 points
Yeah I agree with you Jayar31, like what you said its because registry settings and need complete component. Thanks for your time.
