Overcoming The My Laptop Is Not Charging With Easy Methods.
Hey, how to overcome if my laptop is not charging notify it as stepwise for the better understanding of it same. Thank you for solving.
Hey, following are the step for my laptop is not charging are as follows:
• First open windows > device manager.
• In device manager go to batteries > Microsoft ACPI-Control Method and uninstall the same.
• Now click on action tab and scan for the hardware changes too.
• Next, again go to batteries and then update the ACPI Control Method and then update its drivers successfully.
• Lastly it will asker for drives or can be searched manually too and update the same too
If you have a laptop that won’t charge, there are two possible causes: a broken or faulty charger; a broken battery. In the case of a broken battery, it will still charge most of the time but the battery’s life is a lot shorter. As you use your laptop, the lifespan of the battery decreases gradually overtime as it charges and discharges.
To test why your laptop won’t charge, make sure the charger is disconnected then turn the laptop upside down and then disconnect the battery from the battery compartment. After this, connect the charger back then see if the LED indicator on your laptop lights up or activates. If it activates, it means the charger is working properly and your battery is dead.
At this point, you need to replace your battery with a new one. For the meantime, you can use your laptop with the charger connected but without the battery until you buy a new one. But in case the LED indicator didn’t activate, your charger is probably broken. Try using a different charger for your laptop and see if it works.
If it works on a different charger, you need to buy a new charger.
