Could you tell me how I can solve the problem with the windows encrypted file system that I am facing from months? I allowed encryption on my files, but most of the time, I cannot access them as they show that they are unreadable.
Overview Of Windows Encrypted File System
Hello, The Encrypting File System attribute in Microsoft Windows, which enables files to be encrypted to save private data from attackers whenever there are having direct access to the system. It is the principle behind the windows encrypted file system. So, here are the ways to solve the issue and select which suits the best for you.
a. Press on the Start button and type services.msc and press on the Windows Encrypting file system, then restart the service. Now restart and start using the system.
b. Try opening your system in safe mode, if you don’t come across any of the problems it is because there are some Third-party applications colliding with the windows so activate a clean boot session and delete the unnecessary software in the system. Feel free to contact us if you have more queries.
