Package download error in RAD studio 7
Hello all,
I installed RAD Studio 7 on my system.  However, whenever I run RAD Studio, I get the following error:
Error
Can't load package C:UsersPublicDocumentsRAD Studio7.0BplSamplePackage1.bpl
The specified module could not be found.
Do you want to attempt to load this package the next time a project is loaded?
RAD Studio 2010 and earlier versions work fine. But I don’t know why it is creating a problem now?
It is unable to find the specified module. Why is that so?
Can anybody help me in resolving this error?  I'll be really thankful.
Regards
Ron.
Answered By 590495 points N/A #142318
If this usually happens every time you open RAD Studio 7, try restarting your computer then try it again. If it still fails after booting the system, you should check again the system specifications of the program to help you determine its compatibility with your system.
If you downloaded RAD Studio 7 from a website, try visiting that website again and then check the program’s system specifications. This information should be included on the program’s download page.
You may also try doing a clean installation of RAD Studio 7 to restore it to its default configuration and fix any corrupted files that may have accidentally developed when you first installed it.
Uninstall RAD Studio 7 then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the application again after this and then check if this fixes it.
