Packaged file was not signed correctly. Android
Hello! Buddies,
I am updating a fancy clock and the weather widget app in Android market but it gets me terrified as an error pops up saying, "Package file was not signed in correctly". Is there something I am missing?. Please help me fix this. I need your help guys.
"Installation error
Package file was not signed correctly".
Answered By 0 points N/A #123009
Dear Jeron,
This is a common problem experienced by the most of Android users. There are several reasons to display this message. First your debug version might have expired. There you will have to install a new copy of Android. Sometimes you may have installed another copy of the same software on your device. If that is the case you will have to remove the former version completely from your device and install a new copy to get rid of this error message.
If this does not solve your problem, then try the titanium backup for your roots and reset all your apps, including the system ones. After doing this try downloading from the market.
