My windows is vista home 32 bit and Im playing with packet tracer software but this error is popping out like a mushroom, I don’t have a clue on what causing it but Im sure it not from a certain work.
Packet Tracer
Packet Tracer has stopped working unexpectedly. Please save a diagnostic file and attach it to the reported bug.
Packet tracer has stopped working unexpectedly
The pop up error of “Packet Tracer has stopped working unexpectedly. Please save a diagnostic file and attach it to the reported bug” while playing packet tracer software on your system Windows Vista home32 bit indicates that the files you are using are corrupted and you need to uninstall it.
From the desktop shortcut properties you will get a target actual.exe and from there you will be able to uninstall it. Now you need to create a new file. Install the new one. The pop up error message will not appear any more and you will be able to play it smoothly.
I hope you understand it.
I think you are having problem because of the corrupted/damaged file or having compatibility issues with your windows vista. I think reinstalling would be a better idea. But, try out restoring your file or restoring previous version of the packet tracer. Here's the link for video. If this fails then reinstall the software.
Hope this helps
