Hello all,
I am using the PADS for the last few months but when I try to import something into it, crashes suddenly and throws the following error message.
I can't find any information regarding this error online can anyone tell me what could be the possible reason behind this error and how to resolve it.
PADS Layout – Error
Fatal Data Base Error Number 2015
Invalid Database Object
Job will be backed up to file C:PADS projectsLayout.pccb
Please read the online help topic Recovering From Database Problems
PADS Layout shows FATAL Error and Crashes?
These are the things you may try to fix this kind of fatal error:-
1. Run integrity check using the models command "I". Then try to repair all and save it.
2. Open it using PADS Router and save it with a different name.
3. Open the saved file using PADS layout and run the integrity check once again.
4. Go to File > Export and export the file to ASCII format.
5. Create a new PCB and import that file into it.
Laz Zebbena
It looks like that you have not configured the router properly and this is certainly a problem. You need to identify the terminals that are not connected to the port and then connect it to the port that is not connected till now. Once you will do this, you will find that the problem is gone.
Waters Magner
