The page is faulty with asterisks 3 page frames
Hallo,
Can anyone help me here? The FIFO page trace analysis I am working on indicates that the page is faulty with asterisks 3 page frames in the order of
abacabdbacd. Thanks for your help.
Hallo,
Hello Jed,
Are you working on a Site? or a Software?
If you're working on creating a website page. Then most likely you are having loose codes. Programming languages are very sensitive to syntax codes. In order to debug the problem you need to find exactly the location of the bug you are having. Then fix it there.
If you are working on a Software, you might need to re install the program. Sometimes softwares go haywire due to unknown reasons. Reinstalling it should solve the problem you are having.
Hope this helps you solve the problem
