Page Script Error Dynamic Portal
Hi!
I have a Problem on my Windows Browser. First of All what are script errors and how can I correct them?
I always got this when i open up my browser to search and I keep setting a script error message when I try to log on to a Sites.
Now I can't log in because of script errors.
Help please!
Thank you!
Answered By 0 points N/A #88857
first of all you need to know what is a script , so a script is a set of commands or instructions giving to the Operating System in a special format , it depends on the scripting language you are using, in order to fulfill a task,.
You said that you want to correct the script error , well this can't be done unless you have the source code of the original script to change it then upload again to the server , in other words , unfortunately you can fix this problem on your own it depends of the website you are visiting
Hope this helps !
