riley hall
10 points
Posted on - 02/14/2014
I just want to know why am I getting an error on my IMac The issue I am encountering is attached below. Can someone help me with this? I really need this to work. This occurred when trying to download Lion 10.7.5.
Problem Report for Pages
Pages cannot be opened because of a problem.
Check with the developer to make sure Pages works with this version of max OS X. You may reinstall the application. Be sure to install any available updates for the application and Mac OS X.
This report will be sent to Apple automatically.
Show Details / Ok
Pages cannot be opened because of a problem on downloading Lion
I’m not sure why you are getting this error because updating the Mac OS X operating system is very simple just like in Microsoft Windows where you just need to check for any available update and when the result comes in just install them. Because you are updating to Mac OS X 10.7.5 Lion, I assume you originally have the Mac OS X 10.7 version.
If you currently have something like Mac OS X 10.6+ Snow Leopard and you want to upgrade to Mac OS X 10.7.5 Lion, I think it would be best to upgrade to Mac OS X 10.7 first and just update it afterwards to version 10.7.5 or higher whichever is available via Software Update. If you already have Mac OS X 10.7, you can update to version 10.7.5 by clicking on the Apple menu and selecting Software Update. See image.
On the next screen, you will see all the available updates for your version. Just install them and restart your computer to finish the update. Also, any other update available for the programs installed on your computer will also appear in the result. This is best especially if one of your apps is encountering a problem.
