Hello all! I want to share with you a problem I came across when using Paint Pro X2 and I need to get some suggestions on how to resolve it. Every time I open the application I always receive an error message which has something to do with a specific file with appcompat.txt on the end of it. Why is this so? I need your help with this guys.
Paint Pro 2 appcompat.txt Error
Appcompat.txt is just a way you can send the error to Microsoft. If you do not want to see this error you can disable this in your computer by going to the my computer and then properties. You go to the advanced tab, then to the error reporting and limit the error for paint pro x2. You must be logged on to your administrator account or at least have the rights of changing your settings. The possible cause of this is your paint pro x2 is not compatible to your windows or if you are not using your administrator account you must give a privilege to the account you are using.![](https://www.techyv.com/sites/default/filesx/users/Techyv-Images/Appcompat-txt-is-just-a-way-to-send-the-error-to-Microsoft.jpeg)
