Cole Moreno
30 points
Posted on - 04/11/2012
Hello there,
I paired my sister's Blackberry curve with my android to transfer files with bluetooth. Â She can send me files, but when I try to send her a file. It says on my android that it cannot connect. Â Any ideas on my this happens?
 Thank you, guys!
Pairing blackberry curve to android
Did you check if your Bluetooth is open?you should check your settings on your android phone and make sure that your Bluetooth is open and ready to accept files or ready to receive them for your android phone.
You can try to paired again by closing the Bluetooth connections and then trying to open again the Bluetooth connections and see if you can send her files now, if not you can try the reverse meaning you try to accept files then send again and see if this will work out now.
Or maybe its your Bluetooth signal which is weak so just look for a great location on which you will have the strongest signal on your Bluetooth, and then try to paired again the two cell phone.
Usually it is easier to paired two device with the same name brand because they are both compatible and manufactured by the same company. Sometimes its the compatibility that is the reason why two device will not paired.
