Palm Desktop exprept.exe module error
I installed everything needed to open a document in Palm Desktop but I get the error message below:
Error:Expert.exe module cannot be found.
I’m running on  a very tight schedule, and I need this program get working ASAP.
Thank, you guys!
Answered By 25 points N/A #93485
This is very rare problem; Try to do the following two steps:
1. This problem should fix by re-installing.
2. But if you don't use the cost news role you don’t require it. If you don't necessary it and want to get rid of the bad happening you can attempt to create a text file, it in the Palm folder, and give name it to Expreprt.exe – that way the PDT give experience it when it launches flat-bottomed ' it won't employ.
Hope you got your solution.
Answered By 590495 points N/A #311044
If you are using Palm Desktop on a computer running on Microsoft Windows XP, you should update and migrate to a new version. But first, try to uninstall and reinstall your current version. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Palm Desktop among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install Palm Desktop back. See if this works. If this doesn’t work, download a new version.
Go to How To Set Up Palm Desktop On Windows 10 and try an available version. Palm Desktop runs on Windows 7, Windows 8.x, and Windows 10.
