taaniela
Posted on - 01/10/2012
For 10 years, I have accumulated a thousand of important memos using a Palm device. I need to transfer these memos into my computer. I am using an Apple-Mac but it doesn’t have an Outlook Export Tool. I am still a novice when it comes to transfer device technology. Any help will be very much appreciated.
Twister
Palm device transfer to Apple Mac
i understand, technology keeps changing but all you need is just a little nudge in the right direction. You can use a syncing program like The Missing Sync. Its a software that will help you synchronize your device with your MAC. The Missing Sync for Palm OS is the perfect all-around sync solution for all of your data, files, folders and media.
Hi Taaniela, I have read your concern about transferring important memos from your Palm device to a computer. I have solved this issue with a friend when we tried exporting important files as well. Here are some of the tips and steps we did. First try to unlock the program Palm Desktop, look for the button VIEW then hit Memo preference and you will see the items for export. Then after choosing memos to be exported, look for the menu for RANGE go to SELECTED button hit the TEXT preference for EXPORT TYPE then file is ready for download to your PC.
