PAM Error when upgrading Plesk with CentOS
Posted on - 02/25/2012
I am trying to upgrade Plesk 10.3.1 to 10.4.4 with CentOS. When upgrading the Parallels Panel, I received an error:
WARNING: The PAM configuration is in inconsistent state. If you proceed with the installation, the required PAM modules will not be installed and the upgrade procedure will fail. Some PAM services reference the following nonexistent services: password-auth.
How can I correct this? I already tried re-installing pam but it doesn’t help.
