Panasonic TC – P55ST50 TV Details
I heard the Panasonic TC-P55ST50 tv is now available in foreign countries. I want some details about this 3D TV.
I want details like its Resolution, HDCP compatibility, supported DTV resolutions and its Audio output power.
Hope someone will give me a reply.
Best Answer by Chad Wiker
Answered By 0 points N/A #137810
The new Panasonic TC-P55ST50.
Features of Panasonic new TV
Here are the features of Panasonic TC-P55ST50:
 -FULL HD 3D that is compatible with 1,080p 3D signal and panel has resolution of 1,920 x 1,080p display.
-Infinite Black Pro Panel.
-VIERA Connect WiFi built-in with Web Browser.
-VIERA remote App Support.
-Glass and Metal design (Crystal Frame).
-Screen size is 55.1 inches
-Weight is 90.4 lbs. (41 kg)
-3D real sound
-8 Train speakers in front and Woofer 80 mm
-18 W (4 + 4 + 10) Audio Output
-AV Surround
-Integrated ATSC Tuner
-USB 2.0
-Analog Audio Input (for HDMI/DVI)
-1 Digital Audio Output (Optical)
Answered By 0 points N/A #137811
The Panasonic TC-P55ST50 tv works on the technology called Active shutter progressive 3D method. The 3D effect is achieved by showing the images alternatively to the left and the right eyes. The Eyewear also works in synchronization with this emitting light, and opens and closes both of the eyes in sync with images creating a 3D perception in the brain.
Technical details are:
• Full HD with 3D facility
• Built in WiFi and Web Browser
• 3D Sound
• Dimensions : 51×1.8×32.5 inches
• Weight 61.8 pounds
Panasonic TC-P55ST50 TV
Some other features are that I have better black levels, Excellent audio output, and sleek design. But the power consumption is high, and the images are not very bright. These are some of the cons.
