Hello Friends,
I need a small support from my Techyv friends; I am searching for Panda Cloud Antivirus stand alone offline installer. Please do the needful for helping me to find the download link towards that. Advise me whether I can use it in Windows XP.
Thanks & Regards,
Jafet Windsor
Hi Jafet,
Hope you are fine.
You want to download panda cloud antivirus.So here i am posting link of  latest version of panda cloud.Download type is direct and the downloading will be safe and secure.
http://download.cnet.com/Panda-Free-Antivirus/3000-2239_4-10914099.html
As far as running on windows XP matter concern, Â It will run on win XP smoothly and concurrently.Hope this will helpful to you.
Cheers.
If you are looking for a standalone offline version of the Panda Cloud Antivirus, then your efforts might fail. As the name suggest, Cloud, means it does not have a local database for its virus database, which also means it operates online.
Real time protection is what it offers, so no offline versions available.
