Panda – Data Filter to Check Data
Hello guys,
In the cloud for business need or after all other third party of panda’s Corp structure how would it be possible to get the idea that panda is not using software of data filter to check data in them? Isn’t it like that every datum has to pass over the blur to get protection? So how would you be able for sure that’s without being manipulated as the addresses are what panda can see to fit to go for an instance? How would it be possible to know?
Thank you
