Panda global protection 2013 beta error
Hi, I have recently downloaded Panda global protection 2013 error. After installation this software is using 90% of my cpu. So I tried to uninstall this. But when I tried to uninstall this software I got the following error. Please help me to uninstall or fix this software.
Error:
InstallShield Wizard
Setup has experienced an error.
Please do the following
– Close any running programs
– Empty your temporary folder
– Check your Internet connection (internet-based Setups)
Then try to run the Setup again.
Error code: -5001
Ok
Answered By 10 points N/A #132204
Hello Nevil,
If you have tried uninstalling Panda Global Protection from the control panel and it has refused you will need to try using  Revo Uninstaller to remove it:
  • First of all, you will need to download and then install Revo uninstaller. Note that it opens with all the available programs that you have on your computer. When you check on it at the bottom, you will see the total number of programs installed in your system.
  • After that you will double click on Panda Global Protection.
  • It will ask you to uninstall the program. Just click on the Yes button.
  • After that you will choose an uninstall mode.
  • And then click Uninstall.
Carl
